Convert 3/4 ton to Dually
capthuff
I am looking into converting my 03 2500 silverado into a Dually. Does anyone know what is required to allow for a stock set of dually wheels to work? Or do they just bolt up?
W
watahyahknow
for the front you need the dually hubs (schould fit on the spindles you have ) a dually rearaxle
and the rearfenderflares not sure if you need rearspringparts too you hae to take a look at a dually truck to see
lockone's avatar
lockone
They will bolt up in the front but will sit inside the fenderwells a good bit. Most people just replace the front hubs with 1ton parts and achieve the correct fitment
In the rear if you are going to run a 16/17" dually wheel, I sale the adapters to space your wheels out so that to not have any clearance issues with the leafsprings. You can also replace the axle with one from a 1ton or P30 of any year.
