crazy idea/question
bdydrppup@aol.com's avatar
crazy idea/question
bdydrppup's avatar
bdydrppup
so. this is what happens when u and ur buddy at work are thinkin too much. seein if anybody thinks this would look kinda cool.
so say on my truck for instance you took off the dually bed, put on a standard longbed and only ran the inner semis so all the wheels looked the same. we kinda think it may look cool.
any thoughts? and true it wouldnt be a dually anymore
nighttrain's avatar
nighttrain
Could be interesting once you figured out what to do about the hubs sticking way out.
bdydrppup's avatar
bdydrppup
well i wondered about that too. the short center caps i got from trevor are pretty short but still clear it. maybe stick out a couple inches
Post was last edited on Nov 03, 2009 04:22. Edited 1 time.
nighttrain's avatar
nighttrain
1/2 ton rear with adapters maybe? I think it would look kinda cool
1967rs
It would look like one of the trucks the railroad uses to drive down the tracks.
bdydrppup's avatar
bdydrppup
^^^ thats what we said lol. im kinda thinkin bout swappin one side of mine around to check it out
liljlowrider's avatar
liljlowrider
already been done... it wont let me rob the picture from the site but go to and look under galleries. Alfredo had his wifes dodge like that for while before he turned it into a dually.
lockone's avatar
lockone
Like Justin said above its already been done.
I also have a wheel that we make in 22.5 and 22s that has about a 2" to 2.5" lip on the outside for use on SRW trucks, Hummers, Suburbans, and Excursions.
low95xlt
damn you guys beat me too it on the ram from dima.... how would you do that on the ram??? i think i might try that?? is it all dually hubs up front and a dually axle in the rear?
lockone's avatar
lockone
The Dodge Mega Cab like the one mentioned is a 1ton truck anyways...All you need is a set of adapters and wheels.
If you had the DRW setup in the back you would have to have a large cap to cover the hub that is the only downfall of just running the inner wheel. If you had a SRW 1ton truck it wouldn't be a problem just bolt on and go.
