Lowering on 19's or 22 ?????????
lvnspeed1
Before I get killed with use the search button I did and still came up with nothing. I am lowering my dually (1994 ext cab) 5" in the front and 8" in the rear with air helper in the rear. My question is can I put 19's cut down or 22's cut on and still have it this low? No I wont ask how to cut them down
huskerdually
Why, it just takes a couple of good butter knives and some patience.
To answer your other question. I don't know. What size wheel and tire you running now?
lvnspeed1
becasue I dodnt want to get kicked off the forum in record time Plus I was planning to used a diegrinder to make the tires fit that will work right (NOT)
lvnspeed1
All stock tire size not sure truck is outside and I am too lazy to go out there...... Plus I am suppose to be working.
lockone's avatar
lockone
Your truck should have a 225/75/16 on it stock. This tire is 29.3" tall and the same diameter as a 265/35/22. With the lowering kit you mentioned it will be pushing it on 22s in the rear unless you do something about the fender clearance. 19s will work just fine.
lvnspeed1
Thanks
erock805's avatar
erock805
Trev is the wheel king!
98crewcab's avatar
98crewcab
on the 5-8 drop , you might have to roll the front fender lips to keep the tires from hitting with 19 or 16 stockers....its what I am running
98crewcab's avatar
98crewcab
Trev is the wheel king..........custom cut semi's set up...check out his web site
lockone's avatar
lockone
On the 97 Chevy we have with 19s on it, we didnt have to touch the lip on the inner fenders and have plenty of clearance to turn while riding with the airride on "skeet" mode.
What size tire are you running on your 19s in the front, 98crewcab?
