Carrier bearing removal
snapdaddy
i need help im working on a 80' crew cab dually and im putting in a carrier bearing so far i removed the rear drive shaft and remove the two bolts that hold the carrier bearing everything is removed execpt the bearing it self how do i get that off... i tried prying on it but it dont move... one guy told me to cut it off but im not sure bout that i ws thinking about one of those puller that has the three arms to it but im not sure if there is one that is that long
any help thanks
snapdaddy
chumpchange's avatar
chumpchange
u may be able to pull it they are a bitch after they have been on there for a while. i useually beat everything u can off, useually the actual bearing is seized up on there and i take a cut off wheel and cut the bearing off. good luck
lockone's avatar
lockone
If it doesn't come off with a BFH or some prying then you will have to cut it off. We typically use a die grinder or sawzall.
snapdaddy
yes and now it is in......i win!!! i have about 3hrs total in it this was the frist one i did so now i think i can do it in less time i ended up useing the cut wheel i didnt even have to cut all the way thru it once i got about half of it cut it started to losen up and i took it off from there installed the new one and was on the road in no time
thanks for the help guys
thanks
