SQUARE BODY WITH 22'S?
nuimagemtr@gmail.com's avatar
1niceck's avatar
1niceck
I just picked up a 82 crew cab and i wanted to put my 22's on it does the older truck still need alot of fabrication to keep them from sticking out past the fenders?
distill's avatar
distill
The fronts you will be alright just have to do the inners and lose the a/c, now for the rears I don't know if a cab n chassis rear end will even work because they are so short in width, but it looks 10 times better after you widen them anyways just because of how big the truck is.
1niceck's avatar
1niceck
Wait are you saying i have to take out my a/c in order to put 22's on my truck?
liljlowrider's avatar
liljlowrider
no only if your baggin it.. so dont go ripping it out just yet LOL.. and yea you will still need to narrow the reareand in one of the many ways to get the wheels under the fenders.
1niceck's avatar
1niceck
Oh well the truck is already bagged thats one good thing but its not layed on the frame im gonna throw them on and drop it slow and see if and where it hit. Thanks for the more detailed info.
liljlowrider
if your running a small enough tire it might still fit without hitting..
1niceck's avatar
1niceck
Im running a 265/40 its not to big but not a rubberband.
low1ton's avatar
low1ton
When mine was bagged we got it as low as possible without deleteing the a/c we were able to move it up on the fire wall about an inch and with 265/35/22 on the front my front crossmember sits on the ground when dumped the beauty is I still have a/c but that 265/40/22 up front is about 1" taller. That is the size tire I am running on the back.
1niceck's avatar
1niceck
[quote="low1ton"]When mine was bagged we got it as low as possible without deleteing the a/c we were able to move it up on the fire wall about an inch and with 265/35/22 on the front my front crossmember sits on the ground when dumped the beauty is I still have a/c but that 265/40/22 up front is about 1" taller. That is the size tire I am running on the back.[/quote
Are you running trevors wheels or did you get your own milled? Also how much did you have to stretch your fenders?
low1ton's avatar
low1ton
No fender streching was done running stock fenders. As for my wheels I have had them about 5 years or more and they came from a guy in Florida who milled them. I dont remember his name. On the back wheels he did remove 3/8" off the face of both inside and outside wheels which helped make the whole width 3/4" narrower, but when the truck was bagged the rear end was narrowed and now runs moser axels. Hope this helps.
