Fuel cell?
F
Fuel cell?
F
frozenscubatank
Any one know where to get a 32 or 40 gallon fuel cell thats not plastic?
acid
Make 1!lol
brianbgboy's avatar
brianbgboy
little shop of horrors makes them to utilize the stock sender. call them bro. later, brian
svrdwgn's avatar
svrdwgn
Where are you from? I can give you the numbers to a couple of shops in Southern California that make custom fuel cells...
okcderek's avatar
okcderek
And welcome, seeing its your 1st post...
crazy talk customs's avatar
crazy talk customs
Your going to need to have one custom made. Any reputable shop with a TIG welder and press brake should be able to make you one.
huskerdually
Maybe look into those auxiliary tanks that sit in the bed like a tool box. I don't know what your trying to accomplish so I don't know if that will work for you but it's an idea.
F
frozenscubatank
I just bought an 84 c30 and in the process of bodydropping it and wanted to put the cell in the back of the frame.
huskerdually
Suburban fuel tank?
LL
lizard lips
Fullsize Blazer tanks are 32 gallon and some suburban tanks are 40 gallon. They sit between the frame behind the rear axle. You could check into those and make the mounts to fit it in your truck. Otherwise I would check into a shop to build you one or build one yourself??
