Cold starts
nuimagemtr@gmail.com's avatar
Cold starts
1niceck's avatar
1niceck
When my truck is cold in the morning or if its been sitting for a while when i go to start it up it takes a while to start. Does anyone else have this problem i was thinking its just a tune up that needs to be done. I also noticed it cranks and cranks and when the oil pressure jumps up it fires up.
brianbgboy's avatar
brianbgboy
what engine do you have? these trucks are notorius for injectors leaking down in them causing the hard start issue. use the search feature for"injectors" here, we have gone through this before, and maybe it will help you too. later, brian
1niceck's avatar
1niceck
Ok ill check it out if i dont find it i have a 454 7.4
brianbgboy's avatar
brianbgboy
change over to the bosch injectors from bro. it will get you right. the 7.4 multec injectors just are plain crap. later, brian
huskerdually
Here you go.
huskerdually
Dang you beat me Brian.
brianbgboy's avatar
brianbgboy
im quick bro, and i am even at scrapin the coast right now!!!! i just have explained these injectors on so many sites its like second nature. when someone posts about them my esp kicks in and i automaticly reply later, brian
1niceck's avatar
1niceck
LOL
someotherguy's avatar
someotherguy
Usually though the injector or fuel pressure regulator issues are a warm/hot start problem. I've got that with my '98 7.4, but when it's cold, man it busts off even before the engine finishes the first revolution BEWM it's running. When it's hot, you can just about kill the battery turning that bitch over, then it stumbles to life and shits out a big black cloud of unburned fuel.
I'd start by checking the fuel pressure. Let us know the #'s with just turning the key on, then while cranking, and while running.
Richard
1niceck's avatar
1niceck
So should i put a external fuel pump on it?
