WHO SELLS METRIC FITTINGS?
9
92yota
Edited: 9/14/2007 3:40:11 PM by 92yota
does anyone know where i can get the equivalent to a 1/4" thread 3/8" compression fitting that has metric threads? i need to replace one on a train horn.
i know i can google it, but i don't know what brand would be good and not give me any problems. thanks in advance.
BaggedIndy
Find a swagelok or parker dealer, they will have them or be able to get them.
9
92yota
im still not having any luck. every website i find requires a business account or is just full of pdf's with no way to purchase anything. does anyone know of a particular website that carries this stuff?
BAGWURXCUSTOMS's avatar
BAGWURXCUSTOMS
GO BUY A NPT TAP AND RETAP THE THREADS.....THEY SELL THEM AT LOWES OR HOMEDEPOT. I HAVE TO DO IT TO ALL THE HORNS I INSTALL ALSO! THEY ARE ABOUT $5 BUCK APIECE!
crewcabondubs's avatar
crewcabondubs
i found this site for stainless fittings you can try them
www.buyfittingsonline.com
Gump1986
try mcmaster carr they might have something that will work
9
92yota
ok, buyfittingsonline.com doesn't have metric fittings. mcmaster carr has what i need but the fittings are around $30 to $40 a piece.
so, can i really retap the threads? i don't understand how that would work, since the new threads would be cut through the existing ones. and if i try that and it doesn't work, then im screwed and won't be able to use the train horns. could someone explain how this would work.
boooghar's avatar
boooghar
try the Parker Store in Phoenix AZ or maybe go as far as Catapillar, most of thier stuff is metric
onehot69stepside's avatar
onehot69stepside
Edited: 9/15/2007 2:58:51 PM by onehot69stepside
you would have to go with a larger fitting size so that when you drill with the required tap size, you drill out the threads completely so you have a fresh hole to tap. it sounds to me that if your metric threads are roughly the same size of a 1/4 npt, you will have to increase the size to a 3/8 npt. You might also be able to do something with a Helicoil thread repair kit.
