Cruse Control
Cruse Control
CS
campy sr
Hey...any of you lug nuts know how to trouble shoot a cruse control on a 86 454 crewcab? Mine doesnt work, the fues is good and thats as far as I go. Any help would be great.
Also any help or ideas on installing a subrban fule tank would be helpfull as well.
Thanks guys
Campy Sr.
Square Bodies are the Best
rnonelower
u wanting to put the suburban tank on the dually
jcampbell1180's avatar
jcampbell1180
Yeah. I might pick up a
CS
campy sr
Thanks JG, I know we can do it...I was lookin for someone that may have allready did the drop in to maybe head off some tool tossn and !@#%^& well you get the idea, but what about the cruse control?
jcampbell1180
Yeah, well, in case you havn't figured it out already, I'm pretty much an expert when it comes to these trucks. I'm your one stop shop for square info.
Sike!
huskerdually
I was so confused for a minute!
I saved the tank for my burb for just such a swap. If you want a bolt in deal you will need the burb crossmembers. But it shouldn't take much fab work without them. I wonder if you could Y into the fill and vent hose already on the dually?
W
warpt71
Has the cruse ever worked? The cruse on my '86 is tempermental sometimes. Iv had it not work for weeks at a time! Sometimes it will shut itself off too. What I have found is that it will work again if it is set at the last speed that its was turned off at. It doesnt make any sense to me but it works. Hope that helps
CS
campy sr
No, its never worked as long as Ive owned it...I wasnt sure if there was a trouble shooting test or maybe theres a elec amp draw if it works or.....I do have a vac gage in the truck I wounder if that mite be the problume
jcampbell1180
Bump for the Old Man. He
ben_shady1
Mine is a lil touch and go and I traced it down to the switch on my brake pedal was out of adjustment.
