stock fuel pump in fuel cell
shavenotbagged
Has anyone done this my buddy did on his 99 ranger and it is not that hard to do just use a holesaw and cut the size whole i need im jsut curious if anyone has done this and what everyone did to seal it to the fuel cell casue i still have to get an echeck
tuckin eh's avatar
tuckin eh
I did it on my ranger, just rubber gasket. contact bdpaco on here. he makes an adapter ring for rangers.
BadAssChevillac's avatar
BadAssChevillac
do u just get longer lines if u are runnin it farther than the stock location?
mindlissmetalfab's avatar
mindlissmetalfab
Edited: 10/15/2007 9:15:54 PM by iLLblazer
Use Buna-N rubber. You can get gasket sheet and rings from www.mcmaster.com.
On the 97 ranger in my profile I cut a 1/2" aluminum ring with tapped holes. The ring is welded to the cell. The pump sits on the ring with the gasket in between, and another 1/8 thick ring clamps it all together.
If you need rings cut let me know.
GB
Gangsta Boogie
i did it on my s-10. theres a big oring that sits below the tank surface and makes the seal. i cut the formed section out from the stock tank and tig welded it into my new tank. then used gas tank sealer and coated the tank on the inside.
domepiece
I took the stock fuel pump out of a nissan apart and used it as an inline fuel pump. just connect the hoses to the right sides and put a fuel filter before the pump. It works great. and it's been 2 years now.
