Bolt patterns
erock1969@yahoo.com's avatar
Bolt patterns
erock805's avatar
erock805
Does the dodge dually and chevy dually share the same bolt pattern?
rnonelower
I was told the older ones do like 02 and back but not 100% sure need to PM lockone he will know 4 sure
dropd80s's avatar
dropd80s
The bolt pattern for all 8 lugs from the big three are the same except the "super duty" style fords from 98 up. now the hub diameter is a different story, but it is listed on these forums from lockone. I'll search and see if i can find it for you.
lockone's avatar
lockone
I did a big tech article on the 1 ton bolt patterns a year or so ago and the tech section just kind of disappeared. I will make another and put it in the vendor section.
All Dodges are 8x6.5 with hub bores of 4.773".
73-00 Chevy/GMC are 8x6.5 with a hub bore of 4.567".
01-up Chevy/GMC are 8x6.5 with a hub bore of 4.887".
So you can put Dodges on a Chevy/GMC up to 2000, but not vise versa. However they will not be exactly a hub centric fit but it is very close.
erock805's avatar
erock805
Thanks T!
