Quick question about dually vs. single wheel rear axles
someotherplace@gmail.com's avatar
someotherguy's avatar
someotherguy
OK, so I've got a 14 bolt 10.5" full floater in a single wheel 1 ton, what's different about it vs. one from a dually? Is it just wheel stud length? They seem to have the exact same housing width, and brakes/drums.
Thanks!
Richard
pig rig's avatar
pig rig
its axle lenght and drum size I do belive. are resident swed has the link to pirate4x4 wright up on these rearends
liljlowrider's avatar
liljlowrider
axel lenght.
dropd80s's avatar
dropd80s
Yes the FF14 bolt came in four different widths.
SRW 67.5" WMS
DRW 72" WMS
C&C 63.5" WMS
Van 70" WMS
The SRW and C&C axles have the same axle shaft length, while the DRW are longer, and Van longer still. All hubs on any Full Floating 14 are interchangeable. The DRW and C&C share the same hubs while SRW and Van Hubs are both different. You can mix and match hubs to get the WMS you are looking for. i.e. put DRW hubs on a SRW axle and you have made your self a C&C axle. Clear as mud?
This is Pirate4x4s 14 bolt Bible. Lots of info. easiest axle I have ever put gears in.
someotherguy
Cool, thanks. Yeah after pig mentioned Pirate4x4 I went over there and found the 14 bolt bible, looks pretty useful.
Well fuggit...I was hoping I could use this SRW rear as a DRW without having to change much, but wutever. I've got a nice late model ('99 shitbox) SRW 14 bolt here with 4.10's and a G80 if anybody needs. Make yourself a C&C out of it.
Richard
