cant find drop spindles......
11 following
bdcrewdually
ok so im using 96 chevy 3/4 ton (8 lug) brakes but i was looking for drop spindles and all i can find at like belltech n stuff for the 2500 is only for the six lug not the 8. am i missing somthing here or wat? please help me out i need to get them. i have it layed out on stock arms and spindles but it obviously has to much camber so now i need arms and spindles.
thanks alot with any help
stranger622's avatar
stranger622
Try sporttruckdirect.com they have djm and western chassis stuff
rangerrudy's avatar
rangerrudy
I don't think they make 8-lug drop spindles......
pig rig's avatar
pig rig
I know the answer to this one
the dually spendles are the same as the singled wheel 1 tons but arn't the same as the 3/4t spindles.
why? you ask!
because the brake calipers mount diferently
pig rig's avatar
pig rig
oh wait your working on a shitbox I only know about sqbdys. sorry do your own research
I lied I don't have a Fu<l<ing clue how to fix your problem
bdcrewdually
wat shit box?its an f-ing chevy dually same thing u got. i have 3/4 ton 8 lug rotors.all im askin is wat spindles i need?do i use 1 ton spindles or wat. 3/4 ton spindle is only 6 lug.all im askin for is a lil help
brianbgboy's avatar
brianbgboy
dude, all you need is the dually drop spindles. the spindles on your 96(shitbox body style) are the same as the single rear wheel spindles. technically what we use on the front of our trucks is a 1 ton front hub, but from a single rear wheel 1 ton. the only difference in the setups is the brake caliper and brake line is a little different, but will work. pigrig has a pre-92 model dually(aka squareass body style) let me know if you need anything else... later, brian
rangerrudy's avatar
rangerrudy
^^^^ Yes....but the problem is, when your shopping for 1 ton chevy drop spindles all you find are 1/2 ton or 6-lug 3/4 ton spindles.......I haven't seen any "1 ton" or "3500" drop spindles.....but i could be wrong....
lockone's avatar
lockone
Yes they make them and I have had a couple of sets in the shop.
Belltech is the best for the money.
bdcrewdually
do u know where i can get a 1 ton drop spindle if thats wat i need. i dont see anything either.
