radiator ?
radiator ?
tofnlows10
1st off, i am really not sure what i am talking about/what parts are called...sorry
radiator has 2 (i think 2) fitting that connect to it, that i believe are for the tranny cooler...
bought my truck with a hole in the radiator, do i have to go with the same radiator that has the fittings/plugs, or can i go with a different one and hook that stuff different way?
erock805's avatar
erock805
you could get a seperate radiator and run an aftermarket cooler...be easier and cleaner IMO to just get one with the fittings.
You absolutely need a cooler.
E
ec_dually
i just had to replace mine and i got stock replacment with the cooler line threading.. cheaper that way than trying to rig something up with another cooler...
jeffrodamis's avatar
jeffrodamis
ime going to be replacing mine soona nd i have found that it is cheaper for me to get an aluminum radiator and a mrooso trans cooler than to replace with the same. but i have tha hookup...holla if you hear me...HULKAMANIA BROTHER!
grenier58
use the aftermarket cooler ur tranny will thank you..... and IMO go w/ a aluminum radiator AC guy here and ur condensor will thank you as well and in turn ur air will work more effectivly... not a big notice but where im from any improvment is great!!!
