question for the machinists in the house
Twotipped@aol.com's avatar
Low_SST's avatar
Low_SST
If you were trying to machine a bore for the race on a tapered bearing that was to be pressed in..would you go line on line or a thou under.
jeebus @ mmw's avatar
jeebus @ mmw
depends on what the press is.
with the unijoint cups we make for our control arms, they call for a half thousands press on each side, then secured in with a snap ring. So, i machine the cup to an overall diamiater of a thousandth under size, which is a half thousandth on each side.....
go a thou under overall, which would make a half thousandth on each side.
but when in doubt, call the mfg, and get the specks!
Low_SST's avatar
Low_SST
ok im trying to design a center pivot piece like totally polished did because they cant answer their phones.
bdroppeddak's avatar
bdroppeddak
are you using an s10 wheel bearing?
Low_SST's avatar
Low_SST
no i actually picked up a trailer bearing from timken
1" shaft size and 1.98" od of the race. .58" overall height of the assembled unit
Low_SST's avatar
Low_SST
this is the same PN bearing from mcmaster
Low_SST's avatar
Low_SST
its 10 from center to center of the bar mounting holes to tall for a watts?
bdroppeddak
thats how tall i make them...
Low_SST's avatar
Low_SST
ok ill have some pics of my solidworks assembly in like 10 mins so stay tuned...
Low_SST's avatar
Low_SST
Here is a jpeg of my assembly, Im using 5/8" bolts on the heims and im debating if i want to use a machined and polished post for the bearings to ride on, a modified trailer axle, or 1" shoulder bolt.
if anyone wants a zipped copy of it to play with in solidworks let me know.
