mavverik@sbcglobal.net's avatar
TwistedMinis's avatar
TwistedMinis
Okay I need some help. I did not do most of the dissasembly on this truck, and I also don't have any kind of manual. So I need help figuring out where the fuel lines go. There are 3 at the back of the cab, and 4 on the tank. Which one goes to which piece on the tank? Or does anyone have a stock truck with the bed off they can take a picture for me?
Heres pics:
Where do they go
maz2low
The One on Left with White thing is the Vent Hose usually goes to a hole in Frame . Then the Big one on tank goes to biggest one by Cab . Then the small one beside the big one on Sending unit goes the left Hose by cab if you are looking towards front of vehicle .
lobdyblazr
yeah, the white thing is a vent ( check valve thingy on it)..you can just run a hose off out the way. The other 2 I think are diff sizes, so just run a hose from the larger one on the tank to the larger one under the truck..same with smaller. This is one of the many things i love about mazdas, simple...engine mounted fuel pump. You can use anything for a fuel cell. I have a cutlass tank that i beat down to only 6.5" deep. fits under the bed, off the ground, still holds 9 gallons.
TwistedMinis
Thanks man, thats exactly what I wanted to know!
