link bars
onclemafia@aol.com's avatar
link bars
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
where can i find link bars and urethane ends cheap online? fbimini has em for about 13 per bar
TwistedMinis's avatar
TwistedMinis
Thats about as cheap as you will get. Most places are $10 per bushing, and up.
BggdNBdyDrppdJunk
thanks seth, check out my rear link bar post if you could, i need help fixing a bad custom shop's mistakes
BggdNBdyDrppdJunk
if i get just the bushing sleeves and bushings, can i weld those to a sway bar that i pulled from the yard? its a heavy duty sway bar from a full size chevy van
TwistedMinis
It will destroy the swaybar. Its spring steel. Its properties are changed by welding to it.
BggdNBdyDrppdJunk
so get the threaded bars?
BggdNBdyDrppdJunk
or...what kind of bar can i weld the bushing housing to and still be strong enough?
bdroppeddak's avatar
bdroppeddak
Edited: 5/9/2007 4:31:13 AM by bdroppeddak
we sell em, usually 2 day turn around on any order regardless of bar size/length, but we have alot more than 13 dollars just in materials........
if you are just talking about the ends with bushing and inner and outer sleeve, we have those also, 9.95 EA...... www.gravity-werx.com
BggdNBdyDrppdJunk
those bars can be welded to the sleeves with no adverse effects?
bdroppeddak
both the bars and the ends are A513 DOM, 87000 lbs tensile strength, and has a very strong joint when tig welded......
