speedometer / odometer question
cruisinlowS10
my speedometer is reading fast i.e. if it says im going 25 im really going about 35. My question is, since the speedometer is reading fast, will that make the miles on my odometer turn faster? Autometer mechanical speedometer.
LOWEST1's avatar
LOWEST1
yes the odometer will be off the same amount.
bdydrp18's avatar
bdydrp18
YES THEY WILL SPIN OFF AT THE SAME AMOUNT
cruisinlowS10
any way to correct it? its on a th 350 chevy transmission cable drive into a mechanical autometere speedometer.
bagdb2200
If it says you're going 25 when you're going 35 it's reading slow, not fast. And that's a big difference at 35mph. I bet it's way off at highway speeds. With everything mechanical, the only way to correct it is to change the speedo drive gear in the tranny, if you want to keep the same gears in the rearend and wheel/tire combo.
bodydropped85's avatar
bodydropped85
do you have the right gear for the speedo cable?
