first time metalworking
thebruiser22@aol.com's avatar
trashed's avatar
trashed
OK, let me start by saying that I want some constructive critisism. NO FLAMING.
So I finally got the chance the other day to start practicing some things I've always wanted to learn. My friends truck was in need of some cleaning up so I got to weld and smooth up some non structural parts of the frame. This is only the 3rd time I have ever welded so I am obviously still learning. tell me what you think.
The welder.
What I started off with.
cleaning up the metal to weld.
Laying down a pass. The nasty part in the middle is my first attempt at filling in a hole.
My bead.
Some beads to make it roll down.
again.
finished product. still could use a skim coat of bondo or glaze.
TwistedMinis's avatar
TwistedMinis
Finished product looks pretty good. Turn the heat up a little and the wire speed down a bit. You got too much buildup on the bead.
LOWEST1's avatar
LOWEST1
Nice machine you got there. Very nice start for the third time welding and all.
trashed's avatar
trashed
yea its my friends welder, i was trying to get a good buildup on the bead so i wouldnt have to make so many passes. like i said its not structural, just trying to smooth out the transition.
lunatiksblazer's avatar
lunatiksblazer
i have that same machine with only minor problems ever....heres a question that may blow some of your minds..theres a tig attachement for that welder that i bought. which required me switching to 100% argon now i cant mig worth a shit with argon....could just be me suckin but i wonder what everyone thinks
smctoy's avatar
smctoy
Looks pretty good for not welding but a few times...Seth was right about the heat & speed. Im like you...welding with someone elses welder does make it more difficult. Hell while I was in school I used the same machine for 2 semisters & got so good that my
friends had me fixing all kinds of shit for them lol! Anyway...looking good.
minitrucker04
i tig weld at a fab shop, and we use 75/25 mix of argon!
TwistedMinis
Yeah I hate switching welders. I do shitty for like a week while I get used to the new settings. The gas purge valve is going out on my Miller though, makes it tricky to weld. Its kind of like a car that only you know how to start. Most of my friends can't use it now. Lol.
PleasuresBurban's avatar
PleasuresBurban
Contamination isnt friendly..Clean that metal up more with a wire wheel.
trashed's avatar
trashed
i did clean the spot that still has paint on it with a wire brush because i couldnt get it with a wire wheel. thanks for all the tips guys.
i do have a question though. is there a way to eliminate some of the splatter? i noticed on the side peice i did it looked like it had an exessive amount of splatter.
