infamous fuel cell question
foreverdraggin@yahoo.com's avatar
Forever Draggin's avatar
Forever Draggin
99 ford f150lookin to put an aftermarket fuel cell, prob alluminum
question: if i get a cell with a sending unit thats compatiable to ford..and run an aftermarket inline fuel pump
it should work and my oem gauge should work...right?
tbmx86
It should, but whenI boughta cell for my ranger with the right sending unit that shit didnt work worth a damn on my gauge.
fatheadjames's avatar
fatheadjames
measure your factory sender ohm load full and empty and find one that does the same and it should work
onehot69stepside's avatar
onehot69stepside
i dont know if its the same but I just did an 03 supercrew and just had an aluminum fuel cell built 13 inches deep and used the stock sending/fuel pump with it. All i did was drill and tap the 6 stock holes in the aluminum and bolted it in with the stock gasket and some of that sealant that you use for puttin 2-stroke case halves together (fuel resistant, and I had It) Thats the only thing is it has to be at least 13" deep from the top mounting surface to the inside bottom.If you want to use a premade fuel cell thats shallower, or for ground clearance, you can weld up a little raised box section to the top of the alum. cell to mount the pump/sending unit higher up(clear bed crossmember this way maybe? Ya know fit up inside, in between one of the crossmembers.)
Forever Draggin
what kind of cell did u buy and where did u get it?
still2low4urho's avatar
still2low4urho
ya my one from jegs for my chevy didnt work a damn either...whats up tyler? what kinda fuel cell do you have? I have a buddy who can build fuel cells with your stock pump if you were needing one tyler...just let me know you know where i work
onehot69stepside
you could build one out of steel and use a por-15 gas tank sealant kit on it. theres a recent thread on here about someone trying to use line x inside the tank, and they responded back to the guy with the por-15 stuff
Forever Draggin
yea...i can do that. the prob is i never welded alluminum before...but i can weld some steel. but what will keep it from sloshing around. aint it suppose to be baffled or something?
onehot69stepside
Edited: 3/8/2007 12:35:05 AM by onehot69stepside
all you have to do is make a section in the middle of it, (like a divider in a speakerbox) with the same sheet metal you are using and cut an inch of the corners off so the fuel can flow through the corners of it so when you hit a corner the fuel doesnt slosh side to side. Make bigger corner cuts for the top for the heck of it. You can even make a sheet metal box down in the bottom for where the pickup filter (my dad calls them maxi pads)sits and put a couple 3/8 or 1/4" holes in the sides of it so if it is that low and the fuel tends to move to one side real hard your little box will still have fuel in it for the pickup for that second or so.My trucks alum fuel cell just has the dividers with the corners cut out and my pickup is in the rear of the cell so when i accelerate the fuel is at the pickup And Ive never had a problem with the pump runnin dry. When you mount it, use some rubber or foam between it and the mounts especially on the aluminum. threads into aluminum should be loctited also so they dont seize.
tuckin eh's avatar
tuckin eh
just buy a cell that's the same depth as your stock unit and cut a hole in it and use your stock unit. i did that on my ranger
