S10 HELP PLEASE
S10 HELP PLEASE
HS
hybrid showoff
OK SO I BOUGHT A 99 S10 AND I NEED HELP WITH BLEEDING THE CLUTCH. BASICALLY WHAT I NEED TO KNOW IS HOW. I CANT FIGURE IT OUT AT ALL, IT HAS A 2.2L IN IT IF THAT HELPS AT ALL. ALL HELP IS APPRICIATED.
canadiandime
well your going to need someone there to help you ...first top up the clutch master cylinder with fluid then have your buddy pess the clutch down to the floor well you loosen off the bleed screw. when the bleed screw is loose get him to pump the clutch one more timeand hold it to the floor then tighten up the screw and release the clutch then just top up the fluid level. hope that helps you out bro .
