PLUMBING A HYDROBOOSTER
BEAVERVC
DOES ANYONE HAVE A DIAGRAM OF HOW TO PLUMB A HYDROBOOSTER ON A 2000 CHEVY SILVERADO???? I HAVE THE HYDROBOOSTER AND THE LINES.... I JUST NEED TO FIND OUT WHERE TO HOOK EM UP AT....
choppedn22d's avatar
choppedn22d
Is it the factory one or the aftermarket hydroboost? If its the factory one youre local parts store should have a diagram in there power steering lines book. If its aftermarket call the manufacturer. I have one for my 1996 and it goes like this. Pressure line from the pump goes to the hydroboost directly then i believe there is another pressure line going from the hydroboost to the steering gear box. Their is areturn line from the steering box that goes to the pump. And thier is a return line from the booster also, so you need a reservior with two return inlets. I would have to go check mine to make sure. PLus a 2000 could be totally different.Making this usless just like all the typng I just did, shit.
BEAVERVC
thanx anyways.... it is a factory hydrobooster off of a 2003 chevy silverado 2500, and is going on a 2000 chevy silverado 1500... i was told i will need a new power steering pump to make this work???
