blinker/hazards not working anymore..
detached.org@hotmail.com's avatar
detached's avatar
detached
ok a i have a 98 isuzu hombre basically a chevy s10. while driving the other day my turn signals stopped working my fuses all look good but when i turn on the blinker it dosnnt blink the odd thing is i noticed the brakes wont light up on each individual side thats suppose to be blinking when the blinker arm is down or up for each side.. also when the hazards are on neither brake light will work then however the running lights are fine at that time. is this a relay, short or what?
simple-pleasurez's avatar
simple-pleasurez
check your blinker fluid
http://kalecoauto.com/index.php?main_page=product_info&cPath=2&products_id=6
or check the blinker relay, check the wires,
jblsuburban
you need to get a multifunction switch out of an s-10. to check and make sure thats wat it is turn ur blinker on and hold down on the hazard button gently and theyshould work. sometimes u can wedge the hazard switch and make them work for a while
dwn2erths10
go get a new flasher
SHOWTIME
likejacob said go and get or check the flasher its more than likly toast
detached's avatar
detached
ok ive replaced all the fuses and relays how many grounds are there on the frame after the cab cause im gonna start chekcing for loose or d/c'd wires
91 drggn dime's avatar
91 drggn dime
there is a thing in the column called the turn signal switch box i believe.. its like 450 bucks but they go out so often, oreilys auto parts around me stocks a few on the shelf.. and have been told they go out very often.. i had one go bad on me on a 95 s10
CL
Cruz Lo
If the easy stuff has been checked.....
Sounds like the Turn signal/Hazzard switch in column.
All the Brake, Turn signal, hazzard, and indicator lights on the dash run through this switch on GM.
jblsuburban
turn ur blinker on and play with ur harzard switch and if it starts working youll know wat it is
