got the SD strongarms (uppers and lowers) on a 95 s10, did a stock floor and the 20's are getting + camber so much that when the front is dropped, the fenders bottom out on the tires. The uppers were shimmed all the way, to the point that there is no more room for another shim. Someone help por favor!
bdydrp22
You should remove shims to create negative camber
monkeybags
no, shims create neg. camber on s10s. Do you have the uppers installed on the correct sides? Pictures?
