looking for a "performance"regulator
scottsteeb@yahoo.com's avatar
layedouton22z's avatar
layedouton22z
I currently have a generic regulator with 1/4 ports...and it does not lift the ram very fast. I am looking to find a regulator that would allow a lot of nitro-flow to the bags airing it up faster. any help would be great. If anybody needs a basic regulator let me know as i wil have an extra. thanks
IMLOWER's avatar
IMLOWER
do you have it going straight from the regulator to the valves or do you have a small charge tank between them if you dont add a tank and it will increase teh speed alot
layedouton22z
straight from the nitrogen tank to the valve manifold. no extra tanks
b2low
the tank is a holding point for the nitrogen to build up...then you will get quick lift
mmautoworks's avatar
mmautoworks
you need someplace to accumulate some volume your air can only flow as fast as the smallest point in your system, just a 3 gallon tank in between your bottlew and yor valves will make alot of diffrence
layedouton22z
i'm also looking at 200+ psi to raise the front...
mmautoworks
it takes that much pressure to get it up
layedouton22z
that much clears the tirers so i can turn...bodydrop with 22x on a 00 dodge ram like the pic...not exactly a lightweight truck
mmautoworks
dangggg but you still need a tank
time1's avatar
time1
Put a tank in there and you will be happy.
