Tubing
cbz589@sbcglobal.net's avatar
Tubing
lunatiksblazer's avatar
lunatiksblazer
i was working with some deflection calculations to see what kind of tubing i wanted to use. but this will sound stupid but what kind of steel is everyones tubing.
pimptruckman92's avatar
pimptruckman92
deflection calculations? check out tube chassis:-biomax??? i was askin a similar question this week.
lunatiksblazer
i was talking about rectangle tube. i was wondering if it was 4130 annealed
keele's avatar
keele
2x3x3/16" Cold Rolled Steel. Is that what you are wanting to know
bdroppeddak's avatar
bdroppeddak
Edited: 1/6/2007 4:03:27 PM by bdroppeddak
im assuming you are speaking about materials used for a frame? ive only seen people use run of the mill CR steel.......
BioMax's avatar
BioMax
The only reason that I would use 4130 rec tubing is if I needed to save weight. And then I would use round tubing instead of rec. Rec 4130 is $$$$.
What exactly are you trying to do?
s10
last post by baha +1y
