How to set up a 4-link??
21 following
9
98LowRanger
OK I'm going to be buying Suicide Doors Super lift/pivot triangulated 4 link kit with the bags mounted on the bottom bars. I am 99.9% sure that I know where everything gets mounted, but I don't understand how you set it up before it all gets welded in permenently. I hear you guys talking about setting up your "ride height".....how do you do that? How do you make sure the pinion angle is correct? What should the pinion angle be? Anything else I need to take into consideration before installing the 4 link? Any tips or tricks you guys have to setting it all up? Please explain very detailed if you can because this is my first attempt at this sort of thing. Thank you soooo much in advance!!
Mark
PS - How come kits like the ones Suicide Doors sell have all the brakets for the 4 link except the frame braket like this one from Air Rides website http://www.ridetech.com/productinfo/...es/A116-1L.jpg
TwistedMinis's avatar
TwistedMinis
Whats your email, I'll send you an article that explains all this very well that Max from Bio Kustoms wrote.
9
98LowRanger
Low98Ranger@bellsouth.netThanks so much man!!
TwistedMinis
Sent. Its like 4 pages, but very much worth the read.
whynotfab's avatar
whynotfab
I think I saw where you posted that before Seth and it was really good
/7
///RELAXED 720
Seth I would be interested in readin that too...... if you would email it to me @ lowone@hotmail.com
TwistedMinis
I never posted the article Ricky. Its too long to put on here. But it is a really good read.
Relaxed I sent you a copy.
baggd84
hey send me one as well. baggd84@yahoo.com
or post up a link for it.
TwistedMinis
There is no link, its just a Word document. I'll email ti to you right now.
slammeddime
Edited: 1/5/2007 1:58:13 PM by AirRideTalk dot com
Edited: 1/5/2007 1:01:51 PM by AirRideTalk dot com
Here's a few things I wrote to read over as well:http://www.airridetalk.com/articles/drivetrain/the-u-joint-enigma/http://www.airridetalk.com/articles/suspension/burn-some-rubber/
I'd also recommend taking a look into this spreadsheet, and also consider looking at the library for a book called Chassis Design.
As for 'ride height'. Its just as it says, the height that you will normally ride at. Its definitely not where you are now (unless you are bagged with a different type of setup, but by your questions, I'd gather not).
As for why the SD kits don't have a frame bracket, its because they assume you will reuse your stock leaf spring hanger, but you can order frame mounts for anywhere from $50 on up, depending on what you need.
s10
last post by baha +1y
