sbc motor swap
sbc motor swap
faded avatar
faded
does anyone make sbc motor mounts for a mazda? if not how hard would it be to fab some up? and what are all you guys using for a tranny xmember? custom built or what? and would a toyota rear end be better to use because of the gearing possibilities or what? any help is appriceated
scotto79 avatar
scotto79
www.nolimitcustoms.com has the sbc motor mounts and crossmember kit for 299. The Toyota rear is always recommended because of its strength, its a few inches shorter than the Mazda, and theres a ton of aftermarket for any rebuilding.
faded avatar
faded
thanks for the information man i really appriceate it
faded avatar
faded
that website just sells poker tables
scrager avatar
scrager
motor mounts: if you can weld or know someone who does, go to summit and get the universal chevy small block motor mount bar. it's a crossmember with motor mounts that you can either bolt or weld to your frame. if you bolt, you'll still have to cut to length and weld on the ends before being able to bolt it.
tranny crossmember: i just welded a tab on to my stock crossmember to bolt on the tranny. i'm getting ready to redo some stuff though and will probably go with a custom tube crossmember for simplicity.
maz2low avatar
maz2low
If you dont plan on moving the Motor back into the firewall . You can use the original MAZDA Tranny Crossmember . You can drill the holes out bigger to except the Chevy Offset which is damn near exact to Mazda or you can do what i did and just weld the holes up and redrill . There is no reason whatsoever to change the Crossmember unless you are cutting out the firewell to move the motor in 3inches or so
scotto79 avatar
scotto79
sorry about that Thomas, its www.nolimitscustoms.com
I just forgot to put an "s" after limit
but yeah the universal from Summit is another good option. And the ends of the bar slide inside of the small bar on the mounting plates. So there is no cutting, just welding once they are bolted or welded to the frame.
maddawg avatar
maddawg
trust me, go with the summit crossmember or make your own.
Dupa102933 avatar
Dupa102933
chassisworks.com also has a good crossmember and they have some good lookin motor mounts but dont' waste the money fo the 40 dolla spuds they sell lol waste but they look good
