removing a spray in liner
17 following
shitty
does anyone know a easy to remove a spray in liner????
coptic120
I used an air sander and got it down to bare metal.
TwistedMinis's avatar
TwistedMinis
Aircraft stripper might work.
time1's avatar
time1
Heat gun and a putty knife.
dragwithme's avatar
dragwithme
Originally posted by Shitty
does anyone know a easy to remove a spray in liner????well depeding on wut knind of spray on it is .if it is a soft liner then the only way to remove it is by hand striping it...i spray toff for a living and that is a soft liner ....
NRChopShop's avatar
NRChopShop
shitty
Edited: 12/17/2006 11:35:33 AM by Shitty
i have removed one once but it was a shitty one and it pulled out like a big rubber mat but this one is a harder one it might be ryno or something like that.... i thought of aircraft remover i have a gallon i can try????? p.s. the flame thrower would be bad ass to have
onehightoyota's avatar
onehightoyota
depends on the liner you have. some are cheap and peel up. mine was harder than hell. i had to take a flat wire brush on a grinder and grind mine out. stripper wouldn't work since my liner was gasoline and chemical resistant. mine peeled up in the corners once because of the primer i put under it. big mistake. i peeled out the loose part and had to grind out the rest and had it re-sprayed. an aggressive disc on an air-sander would work too.
c10onfire's avatar
c10onfire
2 metal scrapers, a good friend, and a shit load of beer!
onebadkota's avatar
onebadkota
like they said, it just depends on the type...i got a rhino (polyurathane), and ive removed some of it with a hammer and chisel, just need somethin to get under it....i spray a (polyuria) at work, and its harder than crap to remove..talkin like grinder or wire wheel...--if u do grind though, make sure to use a respirator cause it sucks breathin that crap
