ranger owners i need help
knoxbrendon@yahoo.com's avatar
mitsu94's avatar
mitsu94
my dad has a 92 ranger with the 3.0 v6 and it runs like its runnin out of gas all the time it sputters the whole time u drive it. the check engine light is not on and ive changed the fuel filter, fuel pump, the only other thing i can think of is maybe gloged injectors but i cant afford 2 replace them is there a way 2 clean them out and re use them. ive already tried fuel injector cleaner several times also. please help!
bodydropped85's avatar
bodydropped85
have u checked to see if there are any codes, regardless if the light isnt on? also check the mass air sensor.
gimp5561
check the mass air flow, have advance scan the computer and see if there are any codes reguardless of the light being on. do you know that the light works. where you live
mitsu94's avatar
mitsu94
not sure if the light works and i live in kings mtn nc i have a code scanner but didnt even think about hookin it up because the light wasnt on but ill test it 2 morrow thanks 4 the info
bodydropped85
it could also be the tps sensor to.
mitsu94's avatar
mitsu94
might be a dumb question but whats a tps sensor
holcombe347's avatar
holcombe347
have you pulled the plugs out and checked those? its a different truck all together but my toyota was doing something similar to your discription it would sputter really bad and sometimes die, or coming up to a stopsign it would die. it turned out to be that the plugs were bad...once i replaced them, it ran like a champ. just a suggestion, it doesnt take much to look at a spark plug...at least its a lot easier to get to than an injector. good luck
radical_ranger
i had that same problem with my 90 with the 2.9L and it was the Idle Air Control Valve and 2 of the injectors were so dirty they weren't spraying....you can clean the Idle Air Control Valve with throtle body cleaner but it will only last a few months. better to replace it...and with the injectors you can take them out and take them to an injectory shop or to a carb shop and they can be cleaned and re calabrated usualy cost between 25 and 40 per injector depending on where you take them.
TukinRange
TPS = Throttle Position Sensor. Your Truck is OBD 1 So i doubt the scanner you have will pull the codes if u have a 92, Maybe you have to look at the flashey lights? =)Usually on the older vehicles you have to hook jumpers up and all that crazy shit to make the OBDII scanner work, and if u have a generic one say from autozone or whatever you might not be able or have the proper cartridges to do this. Just sayin...
bodydropped85
it depends on whats scanner he has if itll read obd I. sounds to me either the mass air flow sensor is prob the culprit.
