No lift
dragit@netscape.com's avatar
No lift
dragit89sdime's avatar
dragit89sdime
I just finished bagging the rear of my 1998 s-10 its 4-linked with a bridge notch and bags on the axle, it lays out hard but i get no lift whatsoever any ideas on what i can do to get more lift (im running slam bags)
mindlissmetalfab's avatar
mindlissmetalfab
Edited: 12/7/2006 8:39:12 AM by iLLblazer
Edited: 12/7/2006 8:38:09 AM by iLLblazer
In an over axle setup you will only get the lift that the stroke of the bag provides. So for example if the bag is 3 inches compressed, 10 inches extended, you have 7" of travel to work with. If the bag is not fully compressed when your truck is laid out. (say its only at 5" instead of 3") then you just lost 2" of lift. All you can do with an over axle setup to optimize your lift is set the bag up to be fully compressed when the truck is dumped. If you arent happy with that ...then an over the axle setup wasnt the right choice.If the bag is not fully compressed, you can either lower your upper mounts or fab up a spacer to put between the bag and lower mount. That way you can remove the spacer if you ever get bigger wheels.
dragit89sdime
thanks man ur right my bags are not fully compressing i am going to redo my lower bag brackets 2nite.
