am i crazy,stupid,or is there actually an answer to this ?
17 following
rmcrase@gmail.com's avatar
fatboysS1O's avatar
fatboysS1O
my brother has a 99 s10 4cyl. its been konking out when driving. heres the weird part, it only seems to do it when making a hard left turn. so am i crazy or does somebody actually know what is causing this?
pat2low
check the ball joints
bodydropped85's avatar
bodydropped85
also check the steering stop, put some bearing grease on it, itll clunk at full lock if not lubed.
fatboysS1O's avatar
fatboysS1O
yeah yeah yeah i know check the blinker fluid too. not funny buddy! real answers from now only please!
fatboysS1O's avatar
fatboysS1O
ohh i see what yall are saying, when i say konking out i mean the truck cuts off! sorry about that and sorry about the rude comment there Patrick.
matchead88's avatar
matchead88
Check your tie rod ends and stabilizer bar link. Mine is also a 99 s-10 and was doing the same thing, so i swapped all of the tie rod ends and that did the trick. Good luck.
jmn444's avatar
jmn444
do you mean the engine is dying? or it's making clunking noises in the suspension or what?
fatboysS1O's avatar
fatboysS1O
yes the engine is dying! i guess i worded my first question a lil retarded.
tx raised's avatar
tx raised
check the pittman arm,that was my problem.
STUD1Y's avatar
STUD1Y
are you pinching a fuel line?
is the fuel pump going out? Poor suction happens to be the side all the fuel sloshes away from?
loose wire? only comes off when the body has some body roll?
