Need to make sure this will work.
kaoss84@yahoo.com's avatar
kaoss's avatar
kaoss
Here is the amp I'm looking at:MA Audio M1889i800 Watt Mono-Block High Performance AmplifierM1889i MA Audio * RMS Power Range : 400 Watts * Number Of Channels: 1 * Maximum Power: 800 Watts * Built In Crossovers: Yes * Channel Separation: Yes
Features
* Mono-Block High Performance Amplifier * Variable High/Low Pass Cross-Over 50 - 250 Hz * Variable Bass Boost 0-18dB @ 45Hz * 3-Way Protection Circuitry * 2 Ohm Stereo Stable * High/Low Level Inputs * Low Level Output * Full MOSFET Circuitry * Variable Subsonic Filter 20 - 50Hz * 1 x 400 Watts RMS @ 4 Ohm mono * 1 x 800 watts MAX @ 2 Ohm Bridged * Dimensions(HxWxL): 2" x 10.75" x 11.5"
And here is the subs:MA Audio MA100XE10" 600W Dual 4-Ohm Competition SubwooferMA100XE MA Audio
Technical Specification
* RMS Power Range : 300 Watts * Peak Power Handling: 600 Watts * Impedance: 4 Ohm * Diameter: 10 Inch
Features
* 300W Rms * 600W Max * Dual 4-Ohm Voice Coils * 110oz. Double Stacked Magnets * Mounting Depth: 5.6" * Mounting Diameter: 9.2" * Optimum Vented Box: 1.75 Cu/Ft * Round Port Diameter: (2) 3" * Square Port Area: 14 Sq/In * Port Length: 12.5" * Optimum Sealed Box: 0.5 - 1 Cu/Ft
I want to run them mono at 2ohms stable. I need to know if this will work, and if it will not what amp do I need to look for?Thanks
rickster6924
How many subs r u wanting to use
kaoss's avatar
kaoss
2 subs
kaoss's avatar
kaoss
bump
msturg's avatar
msturg
Nope, it will work but you won't get max performance out of the amp. Your running two dual 4 ohm subs which would either run the amp at 1 ohm (which it's not stable at) or at 4 ohms which would give you half the power of the amp.
You should either go with a 2 channel amp, or switch to single voice coil subs, or lose one of the subs.
dkno's avatar
dkno
dual 4 ohm speakers will give you a rating of 2 ohms a piece, or 8 ohms a piece. so at the amp its gonna read 4 ohms or 1 ohm when hooked up parallel. swap the subs for a single 4 ohm or use 2 amps
rickster6924
Yea ur going to have to use one dual 4ohm sub or two dual 2ohm subs wire in series or buy another amp
rickster6924
Or u can use 2 single 4ohm subs
kaoss's avatar
kaoss
ok, well I'm not getting different subs so what should I look for power and ohm rating wise in an amp? Single channel and dual channel.
thacru78's avatar
thacru78
I'm running .75 ohms to a 1 ohm stable amp right now with no problems. My last system, I ran .5 ohm to a 1 ohm stable amp and didn't have any problems. Both amps were audiobahn. I beat the hell out of both of them and they never got hot or cut off. I ran .75 ohms to a Memphis amp that was 1 ohm stabel without any problems also. Not saying it's right, or that it will work, but it might.
