welders...
31 following
draggingtb@yahoo.com's avatar
welders...
draggingtb's avatar
draggingtb
ok, so my buddy is about to start building his s10 that's been sitting in his shed for a long time. he's looking into getting a welder so me and him can do a lot of work ourselves for our first full build. what kind of welder(s) would you recommend for everything from frame to sheet metal interiors?
bdroppeddak's avatar
bdroppeddak
miller 175.
jeebus @ mmw's avatar
jeebus @ mmw
anything by Miller, lincoln or hobart, that runs off of 220. Dont kid yourself into believing that a 110v welder will be ok, just get a 220v model and you will be at a great starting base.
I personally run a Lincoln 215 for my mig machine, a miller syncrowave 250dx for my tig, and a lincoln 225/125 for arc and sometimes light tig.
taylor
chevyman992002
anything 175amp or over should work.
Iownissan's avatar
Iownissan
millermatic 210
jeebus @ mmw
Originally posted by Iownissan
millermatic 210
Great Machine. i used to own one, and loved it.
doordraggintaco
A 110 WORKS GREAT IF YOU GIVE IT ENUF POWER.YOU CANT JUST PLUG IT INTO A REGULAR OLD GARAGE PLUG.THEY ARE ONLY ON A 15 AMP CIRCUIT OR SO.WE RAN A 30 AMP PLUG OUT OF MY FUSE BOX FOR MY WELDER AND IT DOES A GREAT JOB.I HAVE A LINCOLN 135 WELD PACK.MY FREIND IS SELLING HIS THAT IS LIKE NEW FOR 300 BUCKS IF YOU ARE INTERESTED.
phat phabrikationz's avatar
phat phabrikationz
All I have ever owned are Lincolns. Never had a problem with them. Just make sure u use a 220V welder for any frame work. Any1 that tells u that u can use a 110V welder on a frame is a fuckin idiot. Use a 110V on sheet metal only.
jeebus @ mmw
it cant be said enough.
doordraggintaco
I BET HALF THE NICE TRUCKS ON THIS SITE WAS BUILT WITH THE SAME WELDER I HAVE.I GUESS WE ARE JUST A BUNCH OF FUCKIN IDIOTS.LOOK AT THE STOCK WELDS ON YOUR STOCK FRAME AND TELL ME THEY ARE STRONGER THAN A WELD FROM A 110 WELDER.IT IS PLENTY STRONG.IF YOU ARE USING 1/4 INCH STEEL THEN YES YOU NEED A BIG WELDER BUT YOU DONT NEED ANYTHING NEAR THAT THICK FOR A MINI.TRYIN TO WELD STEEL TOGETHER NOT MELT IT DOWN.
