what kind of wiring and gauge did you use for wiring the valves? i heard you can use speaker wire but i dont know and dont feel like finding out the hard way. thanks.
BlazinKuztumz
You can use speaker wire (16-18ga), or primary wire (16-18ga), both will work. What I usually do is run primary. I take and cut all my lengths, and then clamp one end of two pieces in my vise, and the other in my drill and make a twisted pair. But I have used both, and they both work just fine.
Scott - BlazinKuztumz.com
Rob Clayhill
i used speaker wire as well, makes for a cleaner/more simpler wiring setup.
TwistedPhil
Home Depot sells killer wire- 18/4 Sound and Security cable. It has 4 18 gauge (stranded) wires in a single jacket, and is shielded to boot!
You can run one length all the way to the back, then just strip the insulation to go out to each valve assembly from there. I think if you buy 100' it's only like $.26/ foot.
But yes, speaker wire will work, too- it just looks kind of cheesy.
-Phil at FBI
kotalaynframe
yup i use the home depot sprinkler wire it had like 12 strands inside i wired up my fbss my pressure switch my air horn and still had like two spares all in one
bodydropped85
if u gona use just wire off the rolls, get 2 diff colors, makes it easier
