best place to relocate battery?
19 following
sdime2372@yahoo.com's avatar
jumbo's avatar
jumbo
I want to relocate my battery, but i don't want to put it in the bed (everything's under the bed, so my bed floor is clean). I know i can put it on the outside framerail under the bed, but what about behind the bumper somewhere? there's tons of space back there (looks like). Also, how do i do it? Run the stock cables to a fuseable link then to battery? Does anyone make a kit? Why am i using so many qustions marks? Am i retarted? How do you get teflon to stick to a pan if nothing sticks to teflon?
fatboysS1O's avatar
fatboysS1O
Edited: 10/2/2006 5:22:41 PM by fatboysS1O
yes u are retarded cuz u spelled questions and retarded wrong jackass! anyway,my battery has been relocated to the spot where that lil fucked up flip down chair used to be in my cab.
and what the hell are u talkin about with the teflon?
balcar's avatar
balcar
Nothing sticks to Teflon, so how does Teflon stick to the pan?
Before we dive into that, let's dispense with a technicality: Teflon was DuPont's original brand name for what now goes by various unattractive pseudonyms, such as "non-stick coated aluminum cookware," as well as a poetic variety of brand names. I'll call these slippery coatings "non-sticks."
In the early days, what the non-stick stuck to was a mechanical issue.
Manufacturers textured a pan by blasting its surface with grit, gouging little pits in the aluminum, or by spraying the cookware with a micro-lumpy ceramic coating or stainless steel, which formed mini-mountains as it hardened.
These textures gave the long, slippery non-stick molecules much more to brace themselves against. And when the non-stick wore off the peaks of the mini-mountains and micro-lumps there was still enough clinging to the slopes and valleys to keep the flapjacks flipping. Sort of.
Trouble was these methods didn't hold up very well under normal household use, leading to a chorus of feminine voices across America, singing out in harmony, "TOUCH THAT FORK TO THAT PAN AND YOU'RE A DEAD MAN." (To the credit of these women, of whom my grandmother is one, their 1964-vintage Teflon still appears virginal, while I have forked to death a long, sad series of pans.)
The bottom line was that the non-stick didn't stick to the pan long enough. So, back to the drawing board.
The basic non-stick molecule is a polymer, or chain, of fluorine atoms and additives such as carbon and hydrogen. The longer this chain, the tougher it is; but a molecule that's too long gets viscous and hard to handle.
To move beyond mere mechanics, the frying-pan engineers added a sticky molecule to the non-stick molecule. Non-stick was now applied in coats, with the bottom coat containing the sticky additive that held to both the metal pan and the non-stick molecules. A coat of non-sticky non-stick went over that, non-stick and non-stick clinging together lovingly. A final non-stick layer, spiked with teensy bits of ceramic or other tougheners, protected the softer guts.
This is how lots of non-sticks are made still: Grit-blast the pan; spray on a sticky primer coat, a midcoat, and a tougher top coat; and bake. Oh, yeah: Add colors if you like -- the fluoropolymer is naturally white, but cooks prefer somber saucepans. You may also add a handful of mica, a sparkly rock, to glimmer up the finish.
But the latest non-stick revolution, probably lost on cooks, is a non-mechanical means of sticking non-stick to aluminum. In this method, which DuPont calls "smooth technology," new-and-improved sticky molecules in the primer coat sink as the pan bakes and chemically lock themselves to smooth, unmolested metal. The upper layers fuse together better, and you get a tougher pan.
But even tough non-stick isn't very tough.
Each of the three coats is only about one one-thousandth of an inch thick, for starters. And non-stick softens as it heats, leaving forks as lethal as ever. Plus, raw non-stick is baked on at only about 800 degrees for four or five minutes, so you can toast it if you leave it on the burner with nothing in the pan. Then a rubber spatula, even in the hands of the gentlest grandmother, will slowly disentangle the long, slippery molecules and carry them away.
Which raises the question: Are there health consequences to ingesting all those non-stick molecules? Not to worry, says DuPont's Kris Mohan: We are, after all, talking non-stick. "It's completely inert, and it passes right through the body without interfering with anything."
low mazda's avatar
low mazda
alright. now that we've all had our science lesson for the day.
91 drggn dime's avatar
91 drggn dime
jumbo.. u can pretty much stick it anywhere, you just gotta build a spot for it man. you could go under your bed.. i am going in front of my pass tire, even with 20's.. i'll build a cage for it.
as for the relocation.. i have found going to a stereo store and getting 4ga power wire and ground wire and running that as new cables. also get the ends you need to goto your alt and ground and shit. it is a softer wire, so it pushes mor ecurrent then battery cables do.
truck action's avatar
truck action
Use 0 ga. cable, both on the + & - !! You can get this cable from a welding supply shop( black only)Mark the + cables with red shrink wrap to prentvent any problems!
lester622
phil u must be really bored at work ....
jegs makes a kit it comes wit cables and all the stuff u need for it i think its like 60 dollars.
sadexcuse4s10
i raised mine in the stock location, it's about 4" away from the tire with 20's
mplsrider
yes u are retarded cuz u spelled guestions and retarded wrong jackass! anyway,my battery has been relocated to the spot where that lil fucked up flip down chair used to be in my cab.
We've got way to much in common with our trucks haha.I've also got my battery where my jump seat used to be. and just connected everything up front with a distribution block, also ran a bigger alt. cable but that's not really neccisary.
jumbo's avatar
jumbo
i can't do that, my sub box is in the way, and i screwed a fake jump seat cover in the hole left after taking it out. thanks for the info, though, guys. And fatty, it's not school so i don't get counted off for spelling, i usually correct myself, but i was at the tail end of an 18 pack and not too coherent, lol. Also, i type fast and sometimes don't catch it. And phil, damn, dude, it was a rhetorical question,lol, like why do they call them apartments when they're so close together? Thanks for the info, though, now when someone asks me that, i can whip out a copy of your post and "here's why, fucker!" HAHAHAHAHAHAHAHA
