Where do I start?
Where do I start?
metaltoburn
I just got everything I need to bag my truck: bad mo fukka kit, 4 link 28" lowers and 30" uppers with flex bushings,new link mounts,crossmembers, brackets,drop beams and I'm mounting the bags on the barsBut I'm not sure where the best place to start is out side of removing the gas tank and getting all the stock shit out of the way...I just need a kick in the ass what are your usual steps to installing a four link?
BK2LIFE's avatar
BK2LIFE
umm is your truck notched already?
i usually weld a couple of peices of metal from the frame to the axle to hold it in place, then remove the leafs. the axle will stay in place, and it will be located side to side, and in the place it was in. then do your fab work. but if youve never done this, look at other pics of peoples four links and try to copy what they have done, so you dont have anyproblems when driving
kaoss's avatar
kaoss
i would say mark your axle center point on the frame, set up your fourlink, and then put in the notch. once the stock frame is gone, it's kinda of hard to measure and make sure it's centered.
metaltoburn
no its not notched yet,but thats the first thing I need to do. Should I level out the whole truck on jack stands first?Should I weld the pieces on to the axel with the tires on the ground?how do I find the center of the axel to the frame a plumb bob? should I measure of the brake hub for the link tab placement?If I weld the pieces to axel at stock ride height then thats where my best ride will be right? If I want my best pinion angle to be half that height then this method won't work right?
1los10
ok sounds like ur pretty new to this so u might wanna try to find some good local help. (if ur in the north alabama area i'll give ya a hand). but yea use a plumbob to find were ur axle should be. then position ur fourlink bars and tabs weld them on fully then postion ur notch and weld it in then after it is fully welded cut out the section of frame then let the truck all the way down to the ground and install ur bag mounts. and far as the jackstand thats not a must just make sure its level
SSM-Webmaster's avatar
SSM-Webmaster
Please find someone who knows what they are doing to help out, for all of our safety.
metaltoburn
Actually I'm not really new to this Its just that I've kinda found myself losing touch of all the things I learned on this site and others, past year has been a real mind funk so I 'm not coming into this fresh with confidence...I know my questions are dumb! But I just wanna know the smoothest method is
bdroppeddak's avatar
bdroppeddak
Originally posted by metaltoburn
bad mo fukka kit
where did you get that at?
metaltoburn
suicidedoors.com ya I didn't name it...but laugh it up.
metaltoburn
I kinda figured this thread would end up like this! I understand your were born knowing how to do everything but some of us weren't that lucky! thanx for the help though...
s10
last post by baha +1y
