barking blitzluft valves
19 following
freakwitafro@yahoo.com's avatar
FreakwitaFro's avatar
FreakwitaFro
ok...i have blitzluft 1/2 valves mounted on the bags all the way around on my zu. when i air up the front it doesn't make any noise but when i hit up the rear they bark like a damn seal. i think that air might be blowin thru my dumps in the rear but i was wonderin what others might think the problem might be. any help would be appreciated...thanks.
rangerlayinrocker
haha i had blitzluft valves on my ranger and they made taht noise when i run a bunch of pressure thru them, i dont really think its hurting anything tho
fatman's avatar
fatman
what kind of air are you running
91 drggn dime's avatar
91 drggn dime
my asco's do it at anything over 175.. i think its cool, its loud and makes ppl jump like crazy.
FreakwitaFro
CO2
shideburns's avatar
shideburns
mine do it too at lots of PSI.
i like it, you can definatly scare the crap outta people
SYCOTIK's avatar
SYCOTIK
mine does it in the rear when im at 0psi and tap the rear up switch. and i think my right rear up valve sticks when i do it 2 cause when i tap the rear up i get like 5psi in left rear and bout 70psi in right rear
SoLow03
Man I thought I was the only one that had that problem. It doesn't matter how much air I want in the rear, I am either all the way up or nothing to start with. Anyone know what's up with that?
Chris
Acro Texas
burnsy
sycotik i have that same problem.. dude i cant figure out what to do about it really and i lose pressure in the front when i hit my back up is that normal or should i run a check valve
SYCOTIK's avatar
SYCOTIK
yeah burnsy the blitzluft valves r diaphram valves so theyll only hold the pressure if theres higher pressure from the other side of the valve otherwise itll leak out. a check valve b4 the in-valve will solve that.
s10
last post by baha +1y
