Mini Truckin General
Whats the correct angle to mount your engine? Correct Pinion angle?
General Discussions
smallz
Whats the correct angle to mount your motor and tranny at? And whats the correct pinion angle?
bodydropped85
motor and tranny mounted, pinion angle should be 2degrees positive.
draggintoy
I've read on numerous sites that the carb base should be zero and tanny should be aprox 2 to 3 degrees
suckafree
I always thought motors were at a 7 degree.
smallz
Ive heard 2-3 and also ive heard 5-6. When they were doin mikes toyota in minitruckin they said, 5-6 on the motor.
Dejavu
on the intake flange on top it should be 0 which will give your motor about a 3 degree down slant twords the back.
tofnlows10
heard 5 degrees..
....but if u are bagged it can be less...cause if u drive w/ the front up more then the back the oil will get to the pump fine...
draggintoy
if ya put the carb base ( assuming your running a carb'd motor) at zero i think the actual engine is about 3 derees. but the carb base is zero.
smallz
Im running a fuel injected motor. What if i put a degree level on the valve covers would i be able to use that degree as the overall engine degree?
smallz
Anyone know for sure? I think im gunna mount it at 2 or 3 Degrees
Lowlife Video
CutSceneRyan
11 mo
CutSceneRyan
11 mo
mini chopper frame plans
Krazzypaul
21
Krazzypaul
bomber Seats
Godfather
68
Godfather
Dancing Bed
Dubtruk
Dubtruk
