laying front of a s-10
12 following
dailydragger00@yahoo.com's avatar
riceeter85's avatar
riceeter85
i have a 2000 s-10 iam in the middle of taking out my inner fender wells and i have every thing moved now do i have to cut my frame for my steering i have 17s with 245/45/17 tires and no drop spindals i have upper and lower a arms
HotFreeLayouts.com / frazy.com
N
nbylowrider
with 17" you should not have to cut your frame.
Good Luck
TENONDUBS
cut your frame for what?
riceeter85's avatar
riceeter85
i took them out and my tie rod ends were hitting the frame its stopping my truck from going down in the front so i do have to cut my frame.
insanity's avatar
insanity
yes, you have to c-notch the frame above the tie rods. cut it and plate it!
Drag23onu's avatar
Drag23onu
why dont you have drop spindals
TENONDUBS
NO YOU DONT HAVE TO NOTCH THE FRAME IN THE FRONT. BAGGED BODYDROPPED ON 20'S
dubDyme
i dont think you can lay the front of an s10....to lay on a 17 without drop spindles, itll be really close, depending on the series tire. but if you ever plan to go to 20s or larger, id notch it now just so you wouldnt have to do it later. if you never plan on running bigger, get the spindles and save your frame some torture, cuz you wouldnt have to cut it then.
NOTLONUF's avatar
NOTLONUF
if you plan on running 17's why don't you just fork out the money and buy drop spindles instead of notching your frame when its not needed.
jaredmxg's avatar
jaredmxg
im bd on 20s and it bairly hits on the frame but i have 2" drop spindles, my advice would be to get yourself some spindles.
