Fuel Caps (non-stock)
j-bird
where's a good place to get one? aluminum or pressure release or a motorcycle one.
TwistedMinis's avatar
TwistedMinis
One like this?
j-bird
kinda.....something that can be used instead of the stock. something flush mounted. what im doing is putting my gas fuel hole on my roof. needs to be tight fitting and flush.
that one in the pic,how do you open it?
STUD1Y's avatar
STUD1Y
you push it down and it pops up...
STUD1Y's avatar
STUD1Y
search for quickfill dry break gas caps, they're by far the coolest thing ever
j-bird
David....did you do all the modifying on the gas cap? and what type of trouble did you come across? that gas cap is sick....i like the way they pop up and twist off
TwistedMinis
All the flush mounts pop up and twist out. I used to be able to get them for $35, but then prices jumped.
IMLOWER's avatar
IMLOWER
yea i did all the work on mine no problema at all just picked where i wanted it welded in the bung then body worked it in just make sure you have room under / behind it for your filler neck to hook up to it
j-bird
Seth any new pix of Frank?
David, how tight of a seal does it have? mine will be going on top of my roof, so it will be getting wet. so im just wondering how tight of a fit it has
