Running exhaust next to transmission..good or bad idea?
86nissan720
Im in the middle of doin a sfbd and im goin to have to put a tunnel in my cab for my exhaust and i would like to run it pretty close to my transmission so i would just have to widen my trans tunnel a bit for the exhaust. will that be a bad idea considering the heat that comes off the exhaust or would it cause other problems?
bdroppeddak
if it isnt touching its fine. since it will be so close to your foot/leg you could heatwrap the exhaust.
1los10
yea if u just order some of the exhaust rap from jegs it'll be ok or u could even order some of there heat shild stuff i'm use'n it on my c-10 for the same reason and it works really well
TwistedMinis
Yea just wrap the exhaust. You can get some at a few auto parts stores, and motorcycle shops. A $40 roll would cover the average mini exhaust.
Hc Daytona Dragger
Becareful with the wrap, I wraped my headers on my jimmy and in 6 months they rusted out. It traps moisture along with heat!
NRChopShop
you must not have driven it that much then. Heat wrap should not trap enough moisture to rust out your exhaust in 6 months. Yes its deigned to keep things cool, but the heat is still plenty to keep the wrap dry and evaporate the moisture. Something wasnt done right or the truck wasnt driven.
Hc Daytona Dragger
It was driven on average 40 to 60 miles a day... maybee it didnt help we live 3 blocks from the beach hahahahaha... Its not just me either not to me people down here use it alot
