needin some help
W
needin some help
W
wckdclw
so i went on lunch today from work and came back and layed my truck out....i sat in it runnin 4 about a min then got out 2 go back in2 work......i 4got my phone so i went back out 2 get it and when i opened the doors i smelled burnt wires....i started the truck back up n looked around n didnt see smoke or anything but when i went 2 check the switch wires the switch 4 the back was stuck down.....then it clicked back 2 neutral(sp) when i touched it.....so i figured the wire got pretty hot from it sticking down and sending constant power but when my truck was back runnin after i smelled the burnt wires....my amp wouldnt turn on.....the headunit still worked fine but not the amp.....so...i dunno...any ideas?
DragginHardbody
Check the fuse inside the amp?
W
wckdclw
yea...i did....both were good...and the fuse from the battery was 2.....so i dunno im lost....
