EXTENDING FUEL LINES???
9
92yota
what is the best way to connect two fuel lines, 1/4" maybe, so that gas won't leak out under pressure? i have a brass tube (barrel connector?) that each hose was pushed onto the end of and cremped down, but it is leaking. there has to be a better connector to use.
9
92yota
bump
mazdalow's avatar
mazdalow
Fuel injected or carb?
03on22s's avatar
03on22s
I've always seen just a barb fitting used.
dssur's avatar
dssur
you extend (replace) the whole rubber line from the metal fitting on the tank to the metal fitting on the frame, you dont try to half ass it and use a splice on rubber hose. You are saving what, maybe 5 dollars worth of hose by using an increasingly more and more complex splice? Just replace the two lines with one long enough.
kaoss's avatar
kaoss
a barbed fitting an two worm clamps should work. I replaced the entire fuel line with one the correct length to avoid this problem all together.
9
92yota
i didn't do this, thats why im trying to fix it. i'll just replace the line. thanks for the replies.
kaoss's avatar
kaoss
good call,if it's fuel injected make sure to get the correct line, if it's not, don't pay to much for FI line if you don't need it.
