4 link tabs??
12 following
4 link tabs??
johnz
whats the easiest way to make sure all of them on a rear end are the exact same on each side
86nissan720's avatar
86nissan720
measure them
whynotfab's avatar
whynotfab
Do you mean the spacing from something, or how they are angled or what?
johnz
how there angled
bigjon's avatar
bigjon
calibrated eye!
whynotfab's avatar
whynotfab
Bolt them to the 4link bars, sit in place as close as you can to being identical.. measure each end from the framerails to a certain point on the tab/bolt/end. (at both ends of the bars) and that keeps them all identical pretty much. Can also check angle of the bars in relation to the framerails.. if they both match, and the distance between tabs/frame on both sides, at each end match.. the bars/tabs are identical (spacing/angles/distance from frame)
bdroppeddak's avatar
bdroppeddak
purchase an angle finder.
whynotfab's avatar
whynotfab
^ Yea that works if needing to find the angle they actually sit up and down, but if they're bolted to a bar end they should stay parallel anyway.. Just didn't know what he meant, like what measurement/angle he's trying to keep the same exactly.. =/
drag
Digital Level
whynotfab's avatar
whynotfab
Chuck Norris' Eyeball.
But seriously.. let us know more about what exactly you are trying to measure. Hopefully you figure it out bro.
