metal chop saws
13 following
Twotipped@aol.com's avatar
metal chop saws
Low_SST's avatar
Low_SST
i was wondeing which ones you guys are using and what kind of luck you have with them, ive also been looking at the dry cutting ones with the carbide tippd metal blades and those look promising. any thoughts or ideas?
bodydropped85's avatar
bodydropped85
wet cut i got one last week and love it. not sure the brand tho.
Low_SST's avatar
Low_SST
wet cut is nice, plus they have better clamps then abrasive saws.
slammedxonair's avatar
slammedxonair
is there any that can make compound angle cuts?
mindlissmetalfab's avatar
mindlissmetalfab
the carbide tipped blades are pretty badass. A little scary at first because u dont think it should work, but it does. I used a radial saw style one this summer at work, cut through 1/4" like butter.
Low_SST's avatar
Low_SST
yea there a little pricey, i wanna get something for my shop becasue i have the welder now i need to be able to cut the metal to be able to weld it. ive been looking at bandsaws, abrasive chop saws and these dry ones and the try ones look the coolest to me.
slammed88cutlass's avatar
slammed88cutlass
i got a Ryobi that i bought from sears like three years ago for 210 and have never once had a problem with it. i couldnt live without it. its a dry blade setup which means it gets a little messy and a respirator isnt a bad idea if used in enclosed areas. but other than that it kicks ass. i usually point the sparks into a thick box to keep the vapors/sparks/clean up to a minimum. it cuts fast as fuck through just about anything. harbor freight has cheap ones for about 70 bucks that supposedly work well.
down2earthdawg's avatar
down2earthdawg
I use a dewalt 14 inch dry chop box cuts through 1/4 inch like butter.
Low_SST's avatar
Low_SST
how much was that one, i was looking at it and didnt see any prices
dragginduallydaily
http://www.metaldevil.com/
anyone ever use these? looks too good to believe. but there is video. just wondering if anyone has used these blades and what you think of them.
thanks
