Runs for about 15seconds, then dies??
stevieribotto@yahoo.com's avatar
scr8pen mazda's avatar
scr8pen mazda
Well im hoping that someone will have some things to check for me. Heres the background info: Its an 89 B2200, with an automatic, and its carbed.
This is whats happening:It starts, runs for 10-15 seconds and then just dies... instantly no matter what RPM your at, it just shuts off. I noticed that the accelerator pump in the carb isint squirting any fuel out when i blurp the throttle from the engine bay. However on one of my prolonged attempts to get the POS going... after starting it over and over and over again, it actually kept on running!! and ran for 30min before i turned it off. Anything i should be checking? thanks in advance.
down2earthdawg's avatar
down2earthdawg
fuel pump or filter might be dirty or grounding out some how :UNSURE:
scr8pen mazda
when it warms up above -20 im gonna check the fuel filter and just bypass it to see what happens. nice truck mike, like the rims
dssur's avatar
dssur
that absolutely sounds like the filter or the pump, great guess Mike B. Could be gas tank rust too, clogging the pickup screen.
kindalonismo's avatar
kindalonismo
I had a similar problem with my Nissan, it actually turned out to be the relay. I just thought Id add that in if the pump and filter dont turn out to be the problem
wht01ranger's avatar
wht01ranger
that's what is happening to mine, i have to change fuel filters every month, i need a new tank or get it flushed real bad
scr8pen mazda
thanks alot guys!! the tank is brand new, so it wouldnt be the rust. But tomarrow ill check the relay for sure(ill just bypass it and put it on constant on) and ill check the filter and post back to let you know how it went.. The things you do for women eh?? lol, if it was my mazda, i woulda burnt it
bdroppeddak's avatar
bdroppeddak
does it have a mechanical or electric pump?
scr8pen mazda
fuel pump is electric.
