99 up silverado
suthrn98@aol.com's avatar
99 up silverado
low mazda's avatar
low mazda
are arms or spindles required to lay one of these on some 20s? also, is it required to cut your fenders out?
mobileheath's avatar
mobileheath
if you use a 255/35-20 it it will lay frame on 20's with the inner fender wells still in....also stock arms and spindles work fine...these trucks are a piece of cake to bag
low mazda's avatar
low mazda
what about the rear? if i use the same size 20 in the rear, will i have to remove fenders and how much of my rearend will come through the bed? i still wanna be able to put my bike in this..
Chwelch
Same thing in the back, run a custom notch and you dont even have to cut into the bed.
kleerance's avatar
kleerance
check out my Silverado profile http://streetsourcemag.com/IM/viewusercontent.aspx?IMStyle=2&ID=kleerance
It layed out in the front with 2" lower control arms and just the bag. In order to drag I did have to pull the inner fenders out...Same thing in the rear, it had to be tubbed in order to drag. And just like Welch is saying...if you build a lower profile notch you could probably keep the stock bed floor.
red02chevy
Edited: 2/16/2006 4:06:49 PM by red02chevy
Here is a picture of my truck:it lays on the tranny crossmember with a 255/35 R20. I also have stock arms with Mcgaughy's spindles
