lil bit quicker...
16 following
lil bit quicker...
GN
Green n Mean
sup guys, my sierra is bagged with 1/2inch 450 GC xtreme valves and line with 2600 conitech bags all the way around, (3) 5 gallon tanks with an engine driven compressor and a 145 pressure switch...the thing is i want more quickness in my suspension movement in the front...what would i need to change?the back is quick as hell but it takes me about 6 seconds to raise the front all the way up (5.3 motor) and id like to cut that way down...and where can i purchase the equipment?
Bdierks
mabey a bigger pressure switch would help.
N
nvrlowenuf
Where are you valves for the front mounted at? The closer you have them to the bags the quicker it will lift.
sadexcuse4s10
200 psi or more will help alot
145 is slow on anything
s10bd
What about a charge tank in front?
Stock Sucks's avatar
Stock Sucks
I have always heard to do this but i guess i dont fully understand why if the airline is pressurized as well, why would it matter, or how does the airline effect the flow if there are no sharp bends or fittings?
wht01ranger's avatar
wht01ranger
it's not quite quicker, just quicker response time
Stock Sucks
yeah i guess i can see of there is no air in the bag, the shorter line b/w the valve and the bag would help the response time but i didn't think the actual filling of the bag would be faster...only way to get the truck to lift faster is better PSI right
Stock Sucks
i mean a truck is always gone lift faster at 140psi than 100psi...
Twisted Galant's avatar
Twisted Galant
More pressure. and more air
