grounding my valves?
dragn168@hotmail.com's avatar
dragn168's avatar
dragn168
aight just wanna knowif i should ground the valves to the body or to the valve it self the kid who wired my valves up the first time did both just wondering which is the best way seeing as to how im about to add four more valves tomarrow i just need to know if i need to run out and grab some screws to ground these things to the body
95FullSiZE's avatar
95FullSiZE
i figure grounding them to the truck would be the best way it's how i do mine.
thunderbird's avatar
thunderbird
Edited: 1/25/2006 8:08:58 PM by thunderbird
the only way i see the body of the valve being a ground is if it is hard mounted to the truck with a metal bracket. the the valves is cool. why not just go to the body.
I actually have my switches wired into the ground portion of the circuit
dragn168's avatar
dragn168
just wondering cuz i have the new valves all set up in my room i was gonna see if i could just ground them to them selves and then just put tthem on the airline
bodydropped85's avatar
bodydropped85
mine are to the frame.
rangerrudy's avatar
rangerrudy
If you ground them to the valve you will have to mount the valve to the frame or body so it will make a circut!!
s10
last post by baha +1y
